My brother and I restored a 1973 MF 135 UK. This site was very helpful with lots of our re-assembly issues; and being new to tractors, we had lots.
Now that it's been on the road for almost a year, maybe it's time to finesse the brute. One issue that's been bugging me is the slowness of the loader to raise when the blower is attached. I'm aware through reading a lot that the 135 single pump wasn't made to have both implements and slow is normal. But, here's the rub. If the blower is raised high, the bucket is excruciatingly slow. However, if I drop the blower almost to the ground, the bucket goes faster; not fast, but faster. Knowing that the lift control lever has to be all the way up for bucket to work, is there a correlation between the full up bucket position and the position of the lever when it was controlling the blower? It seems the further apart those two positions are, the better the bucket works, or am I dreaming?
My simple mind has concluded two possibilities:
1. The rigging of the hydraulic position levers inside the lift cover is not exactly correct; or
2. I might have lower than spec hydraulic pressure.
Respecting #1, certainly a possibility since it's the first time (ok, third) we've done it, but it should be pretty close. Worth investigating if you think it's worth it.
As for #2, hydraulic pressure could be an issue. We replaced the valves, fluid, filter, bypass valve, new O rings and backing on the stand pipe and o rings on the TS300 but, the pump does have 3000 hours on it.
I think the next step might be checking output pressure, but I'm not sure where to do that. Would it be possible to get a good pressure reading at the #3 position on the TS300 (nothing connected there now). I know you're not supposed to dead head a hydraulic line, but we know that the bypass valve works well. Is there anywhere to get pressure from the lift cover? Installing a T fitting is best, I know, but that's a lot of work and expense.
I'd be grateful to hear what you think. Thanks again and again. And, I have no idea why the photos load sideways.
