Hi guys,
I've owned a 1085 for a few years now and im starting to wonder if the MP is slipping. some info on the tractor, it's got around 4,800 Hr. and it's turned up, probably slightly over 100 HP. was used just for mowing hay and light disk work, but now it's my planting tractor along with baling tractor.
i'm trying to determine if the MP might be getting weak or if the clutch might be starting to slip? the MP still holds back and functions but it seems like i use to remember when i was on the road and hit it the tractor would jolt into high. now it seems to be more of a gradual take off. With that being said I was pulling a 4 row planter the last time i was out so maybe the extra weight was causing it? If i'm on the road and i have a big hill, when i lug the tractor down i get a smell in the cab, almost smells like paint burning or something, i notice it if i'm on the high or low side of the MP. not sure what that might be, but i'm hoping it's not the clutch packs slipping and me smelling that?
Also i'm noticing that if i park the tractor in high range on a steep hill the tractor will want to coast some instead of holding itself. this is what makes me think the clutch could be the problem.
So if the MP is starting to go do you guys have any recommendations on what i can do to get through planting season and most of my hay season?
i have a 2nd question as well, right now my C-IH planter should be running with the hydraulics in the float position for the row markers to keep contact with uneven ground. is there anyway i can upgrade the valve for my remotes to have a float position? I figure if i'm going to need to tear the trans apart i might as well try to work on that while i'm in there if it's possible to run a float valve on these tractors.
Thanks,
Guys!
Thanks,
Guys!
