I have a new 150 and I'll be doing the oil and hydraulic fluid changes for the first time. It's hard to find info on the 150 bc it's kind of a cross between a 135 and 165 from what I understand.
Motor: I can't find the part number for the right oil filter for the Perkins diesel. I've read is 15w40, I usually use 10w 30 or 40 in Western NY where I plow in some single digits temps and I would never use it over 90 degrees. Is 15w40 still best? Is 6 1/2 quarts the right amount?
Trans/3 point:. I can't find the part number for the right replacement screen/filter for the hydraulics. Anyone know the part number? I also want to flush out the system with diesel...should I do this before or after I replace the screen? And does the sump take 7 1/2 or 8 gallons I've gotten mixed info on that.
Thank you so much for your help, the shop manual I have leaves out a lot to say the least.
