Company Logo Shop Now
TractorLinks.com
Massey Ferguson 150 dies
kscessnadriver
05-15-2019 13:26:30
So I've got a MF150, diesel, that I've recently developed an issue with. It will run fine for say 30 minutes or more (while I'm out mowing with it), then it will start to have some RPM fluctuations (+/- 250 or so RPM). Shortly after that, it will finally just die, as if its lacking fuel. Based on what I've researched so far, the common culprits could be either; 1)clogged fuel lines/blockage, 2)fuel filter issue, 3) lift pump issues. After it dies, I'm able to let it sit for 5-10 minutes, then crank it for 30 seconds or so and it will fire back up and run for a while longer.
So in the meantime, I've drained the fuel filter by using the drain plug on the bottom of it, allowed it to refill and bled the system. I'm inclined to believe it's not an issue with air getting in the system, as every time I've bled the system, it's not taken hardly any time at all to get fuel out of every spot. I do notice that when I use the lift pump manually, I don't get fuel to push out. That leads me to believe it's time to replace the lift pump.
Is there any chance that the tractor would run like it does with a bad lift pump? Or am I chasing the wrong issue.
ptfarmer
05-19-2019 20:32:42
 Re: Massey Ferguson 150 dies in reply to kscessnadriver, 05-15-2019 13:26:30
That will do it, I'd get a couple of extra fuel filters to keep on hand just in case.
kscessnadriver
05-19-2019 15:37:54
Just to update, got back to the tractor to work on it. While I don't have it running yet, I'm 99% sure it was the filter, as pulling the old fuel filter revealed it to be clogged with a large amount of rust/sludge. Once I get the system bled out, I'll know for sure.
kscessnadriver
05-16-2019 14:21:43
Thanks for the ideas, I ll work on some of them when I get a chance, I ll be out of town for the next few days. I ll report back when I get a chance. I replaced the lift pump last fall, might have just got a bad one to start with, happens when they re cheap these days.
Dieseltech
05-16-2019 04:39:23
Yes, it can be a bad feed pump. A GOOD pump will shoot fuel out the TOP cover bleed screw with engine running. You may also have the constant bleed orifice plugged on filter base top return line. Call me at 574 835 3292 if you like with any questions.
Bob N.Y.
05-15-2019 19:15:05
Have you changed the fuel filters? Do that before replacing the lift pump.
Phil Tibbetts
05-15-2019 14:20:54
First thing I would suspect is the coil. See if it is hot when it dies.
Phil Tibbetts
05-16-2019 03:07:54
 Re: Massey Ferguson 150 dies in reply to Phil Tibbetts, 05-15-2019 14:20:54
Sorry I missed the diesel part, another senior moment.
MikeinKy
05-15-2019 18:37:17
the only diesel I have had with a coil is an 820 John Deere. I would look for a fuel blockage somewhere.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
