MF50 neutral switch question
16840138
I installed a new neutral switch along with starter switch and solenoid. Used bullet connectors to the neutral switch but no starting, Pulled the wire out of the switch and reinstalled; the engine started 3x no
problem. The next time I tried nothing until i wiggled the bullet connector. Have shifted the high low to neutral and back and forth. Still no starting. Where do I go next.
Thank you
There's still a bad connection somewhere, does it act up with the two wires hooked together which bypasses the safety switch? May still have trouble with the push button switch, solenoid switch, etc..
Replaced solenoid, starter switch, and neutral switch along with the wires. Added bayonet connectors for the safety switch, and it is when the bayonet is pulled out but not all the way it starts 3x no problem but the next time one goes to start it is back to pulling the bayonet connector up and down. Thanks John
