Alanjohnston
New User
I recently purchased an MF35 with the 3 cylinder Perkins diesel and it is very hard to start cold. Once started it runs great, good oil pressure and restarts easily until left over night. Then I can only get it going with a spray of quick start in the air intake. I have put two tanks of diesel through it so all the old diesel should be flushed out. I changed both fuel filters and I cleaned the air filter and replaced the oil in the filter. When I open the bleeder ports and turn the key there is a good stream of diesel from them. Any ideas why this engine which is renowned for being a good starter has so much issue starting cold? The key does not turn back to the heater option so I haven t been able to try starting it with that method.
