Company Logo Shop Now
TractorLinks.com
Re: MF65 For Sale
Slomo
04-15-2019 13:18:43
Technically, yes there are 12 speeds forward. However there is some overlap. I’ve only experimented with the crawler transmission but in my assessment, low gear in the crawler has approximately the same reduction as low range in the front transmission. So what that means, you can put the front transmission in high range and the crawler in low range and the performance would be the same as just low range in the front transmission. The only time you would use the crawler is when you’re in low range in the front transmission. So really it only gives you 3 more gears forward. I suspect the crawler works in an “in and out” fashion and as I mentioned, with the same gear reduction as low range in the front transmission. I hope that makes sense. The aspect of it that I really appreciated was the extra leg room.
