purpose of buss bar on MF50
16840138
According to the wiring diagram there is a bus bar used on the MF 50. Does anyone know where it is located? Along with a source for a new one. Thank you again John
I may be wrong....but I believe it is a wire substitute that runs between the key switch and light switch??? The two switches are so close, that they just put this bar in instead of a wire. How about it everyone? did I guess correctly?
Wayne
(quoted from post at 19:18:52 04/07/19) I may be wrong....but I believe it is a wire substitute that runs between the key switch and light switch??? The two switches are so close, that they just put this bar in instead of a wire. How about it everyone? did I guess correctly?
Wayne
It is very possible they did use the bar instead of a wire, they do use a bar on starters where the solenoid is mounted on the starter.
