massey 2135 3 point
Goalvanny
New User
i have a 2135 and im trying to adjust 3pt. with draft control all the way back the posistion lever works fine. if i lift up brush hog all the way up with position lever and then move draft lever at all it drops the mower is that correct? if i put draft in center posistion i get nothing from the posistion lever. this is all with the response side cover off. pressing on the sensitiveness nob while lowering thats working. thanks
The draft lever is NOT to be used for the bush hog, position lever is to be used for tools you want to hold a certain height above ground. Draft is used for ground engaging tools, mainly plowing..
i understand what draft is suppose to do but if im understanding correct it should not effect the control of the lift if not using force such as plowing. but im young maybe im wrong with that.
For the position lever to work correctly the draft lever should remain in the transport position. For the draft lever to work correctly the position lever should be in the transport position. In other words both are not to be used at the same time when bush hogging or if you are plowing land.
