I have a 9N tractor that has been converted from 6 to 12 volts. It runs like it is starving for gas. At idle or fast idle it seems to run fine but when you try and do any work it will die.If you pull out the choke it will rev up again. The shut off valve/glass float bowl had been replaced with a petcock and an inline filter at one point.This has recently been converted back to the original shut off and float bowl.As well the inline filter has been removed as I thought it might be plugged. All indications are that is is a fuel supply problem but I can't seem to find out why.
Any suggestions.
Any suggestions.
