My MF65 is a 1961 model. Last fall the hydraulics were jerky, both the 3pt and the loader. I referred to my ITmanual and eventually replaced the hyd pump (sourced from YT) It was operating smoothly, and I used it all winter pushing snow. I noticed that it was struggling to lift a loaded heavy wet bucket so I put a oil pressure guage on the test port and only register about 800psi. The manual calls for 2300-3000psi. I took the inspection cover off and could not see much of a disturbance of the oil going on and replaced the stand pipe O rings as well. Could it be that the pressure relief valve on the pump is not set for higher pressure and how do I check if it is not. Thanks for any tips. I can use it the way it is but it doesn't lift much. Leon
