Front Axle support question
I am in the process of reinstalling the big cast front axle support that bolts to the front of the oil pan on my MF35. When I took it apart to rebuild the engine there were only 4 of the 6 bolts holding it to the pan. There are threaded holes for 2 more on the bottom but the bolts were gone. My question is do the bolts come in from the front or do they somehow fit through the slots in the side of the support and then bolt in. If they came in from the front that would make them about 10 inches long. Has anyone ever run into this.
To answer your question, yes, their should be 2 bolts their ( 5/8" X 11 5/8" NF, Hex ). according to the parts book. You can view the complete parts break down for your tractor at (AGOC Parts Book) online, sign in as a guest if you don't have an account with a dealer and look up your model. Book 651093, Front Axel support,pg. 110, item # 35, shows the bolts.
