unknown tractor?
pjbirney
New User
I recently purchased a MF loader construction tractor in great need of repair. The decals and model number were all gone, but the serial number [ 9A211887} suggest that it is either a 1975 MF 165, a 1975 MF 175, or MF 275. The 165 four cylinder diesel would be either 3.3l or 3.5l Perkins, the MF 175 would be a 3.9l, and MF275 a 4,1l Perkins. The loader is a MF 30 making a 165 or 175 more likely. The engine block has a casting number of D3 2G4. I would appreciate any help in the identification of my tratcor, or any construction tractor manuals available. Thanks Paul
Look closely on the engine block, it should be stamped with the CID too. One clue, if exhaust and intake are on the same side on the head, it's a 236 or 248. The Perkins 203 is a cross flow head, exhaust on the injection pump side of the engine and intake on other side.
(quoted from post at 17:56:15 02/15/19)
Yes, ptfarmer, your photo looks exactly like my tractor without the loader, thank you so much. Are you aware of how to get any manuals about this tractor? Thanks Paul
