Massey 135 Fuel Line
rgreer36
New User
I am having trouble removing damaged fuel line that goes from injector pump to fuel filter housing on my Massey 135 diesel tractor. The end that goes into fuel filter housing will not pull out, any tips for removal? Also any recommendations of online parts company to get a new fuel line. Thanks
I make my own out of the metal brake lines you get at the local auto parts store, you just have to reuse the original nuts on the end (see picture below, I made the lines from the lift pump to the filter, and the return from the filter to the tank). The ends that go into the filter housing can be a real pain if the butt to remove, can take a bunch of time, and effort to remove.
If you can get them out I use the old brass barrel shaped ferrules to replace them. They don't need to be too tight as there is not much if
any pressure. Just my 2 cents worth.
Yes at others said the ends of fuel lines
have these small black rubber seals called
olives. Look like a sliced circular olive.
They get hard and need to really pull hard
to get out. Same on lines to the lift pump
too. Order a bunch of olives with new fuel
line.
