David Fisher
We pulled the left axle a few weeks ago and removed the discs and actuator to make sure I ordered the right parts. Rivets had cut pretty deep so I'm replacing everything. Pulled that axle again this morning placing all the new parts inside. Moved to the right hand side and found the outer axle seal is leaking bad, Discs had been replaced on this side before many years ago, probably for the same reason... Really not a bad job so far, even the differential lock on the right side is kind of easy figure out. So what am I going to find on this outside seal area? Felt like the axle might pull out of this end part toward the inside while I had the whole axle off the tractor but not sure. For now until a seal is ordered I've put it all back together minus the brakes and actuator because I have to have it mobile to move outside the shop.
