Company Logo Shop Now
TractorLinks.com
fuel filter coversion for massey 135
valley iron
02-09-2019 14:10:05
i was wondering if they make a conversion kit to change fuel filters with glass bowl to screw on type? mine has the double base and i HATE fooling with those darn rubber rings that never seem to fit right. anybody know if they make these for a 135 with double base and if so where i could get them? bty it is a diesel
Cormiers Cove
02-23-2019 16:39:08
 Re: fuel filter coversion for massey 135 in reply to valley iron, 02-09-2019 14:10:05
I changed both the primary and secondary on my 1964 35 deluxe with screw on filters heads. I did a bunch of research to make sure I had the appropriate filters as the secondary is different than the primary.
If your 135 has 2 filters as some only had one you can buy a dual spin on filter head. Or use two single heads like I did.
ptfarmer
02-11-2019 09:27:10
I got this filter base from SSI Diesel in the UK, it's a lot better than the adaptors, here's the one I put one my 135.
The old filter vs the new!
bowtieboy77
02-09-2019 21:16:42
I have a 135 with perkins gas engine and I was having issues with the glass bowl sealing. I was also not willing to buy a new one as they are quite expensive. I got rid of it and threaded a inline filter into the carb. I believe the filter is for a late 70's ford truck but thread size is same as the carb.
Jim.ME
02-09-2019 16:51:29
A few more things as well. The spin on filters will cost more as well. Need to get a spin on with micron rating to match, or better, of the cartridge filter. Set will likely be longer than the current set up, so need to check clearance below the current set up.
I'll keep using the cartridge filters.
Phil Tibbetts
02-09-2019 16:37:14
Price is not cheap 60 to 100 bucks.
Jim.ME
02-09-2019 15:10:45
There are several conversion kits available. The store for this site may have them. Wix, and likely some others, use your old base with adapters. Some of the single kits change the whole base, that option may be available for the duals if you research it. The Wix number for one adapter kit is 24038, NAPA is 4038.
Dieseltech
02-09-2019 14:49:03
I think the reason some have trouble is there are two large O ring sizes, and a fellow has to be careful using the larger one in the base groove. I don't mind changing those filters, but I've done it for years too. Spin on filters do spoil a fellow though..
DavidP, South Wales
02-10-2019 05:39:43
 Re: fuel filter coversion for massey 135 in reply to Dieseltech, 02-09-2019 14:49:03
Hello, I would agree that you have to be carefull. In my 45 years of fitting these filters I have always compared the length as soon as I take them out of the box. The longest one always goes at the top. The material in the rings has changed slightly in the last 20 years or so and it can make them a little more difficult to seat. Non-genuine filter bodies are available although I have had some problems getting a seal at the pipe fittings. It is almost as if the face and thread are not perpendicular. Probably plenty of alternative filter set ups around but then you will probably have difficulty matching fittings and threads.
DavidP, South Wales
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
