Can you weld this
Rkh
Pin came out of center rear lift on 3 point, broke onbe ofbthe lift arm. Can you weld the 2 pcs together?
Hi, a sleeve is fine but in addition the both ends should be ground off to a chisel profile and weld applied to both sides evenly. If done correctly you should not need a sleeve but it would add extra strength.
DavidP, South Wales
I've have had total success on both the MF FE 35 X and the TEA-20 lift Arms.
What appears to be a previous repair was not attached with both components AXIS in alignment.
A couple of spelling errors..:)
Bob...
