Time to do the brakes on our MF40 loader. Started with the right side. Separating the carrier plate from the axle was long and slow. It fought me the whole way. I think it was the reaction pin that was
tight after all the years. Is the reaction pin, shown right in the pic below, pressed into the axle housing, or should it be free enough to come out of it's socket. I had to disassemble the actuator to get it
out because it hung up on the reaction pin when trying to take it out as a unit. Reassembly would be a lot easier with that pin out of the way. It is currently solid in it's mounting. My sense is it's meant
to come out for brake servicing but just seized after decades in there. Is this correct? If not, did I miss some trick to getting the actuator out as a unit?
