Dual Power use
How many of you guys use the dual power on your 35`s. It looks like all of mine is there except for the bent rod that goes from the lever to the top of the bell housing,. Lawnmower mechanic must have tossed that too. I was just wondering if its worth trying to reconnect it.
Right now the rod is down so I guess they just disconnected it and left it there. Do you use it regularly if its something I might use I will try to find the rod for it. Mine has the rod cut off just outside the bellhousing and a nut clamped on it.
