TexasMF135
I have a Massey Ferguson 135 with a live PTO. While it still operates fine, The exterior splines are worn to a point that I would like to replace the PTO shaft, rear bearing, and seal. While browsing the Parts manual from YT I cannot determine (from the kitchen) if the other end of this shaft is 10 spline 181 201 M92 or 21 spline 1 868 557 M93.
I have always preferred having the new parts on hand before dis-assembly.
Any suggestions other than pulling the shaft and waiting on parts?
1974 model with a Perkins 3 cylinder diesel, lower exhaust outlet, 5 gauges but no multipower, it was used on a peach farm for 30 years or more but it is not an orchard model.
PTO lever has ground drive-neutral-engine PTO lever under left hip when operating. dual clutch and dual input shafts because clutch, throwout bearing was replaced during an engine build 8 or 9 years ago.
