I have recently had the engine in my Massey 35 completely overhauled and as the mechanic was putting it back together he seems to think there is an issue with either the injector pump or injectors causing it to run lean which lead to the original problem of burning a hole in a piston. He is saying we need to have the pump and injectors tested to see which is bad and them have them rebuilt or replaced. I called a well known diesel shop and the gave me a price of $20 to test each injector and $60 to rebuild each and $175 to test the pump and $750 to rebuild it. I see where new injectors are only $20 each and the pump around $700. I also have seen a rebuild kit for the pump for as low as $11. Am I missing something here? Paying more to have everything rebuilt rather than buying all new? Should I start with replacing the injectors and a rebuild kit? I am open to any suggestions. Thanks in advance
