Neither Pitman Gear Shaft has any marking to time them to the main shaft.
None of the manuals are clear enough for me. The clearest one says
1. Turn the steering shaft until the lower tooth on the ball nut is visible through the right opening in the housing.
2. Install lower pinion shaft and cover assembly with the blank portion of the teeth down, and the lower tooth on the steering nut meshed with the groove next to the blank portion.
3. Turn steering shaft until the center tooth on the top side of the lower pinion shaft is in line with the opening in the left side of housing.
4. Install upper pinion shaft with the center groove mating with the center tooth.
It then goes on to say that when the gears are matched correctly, steering is 3 1/2 turns from full right to full left.
#1 is clear
#2 getting through off by the cover assembly, if I can drop that from the install instructions then I am clear. If they mean I need to install the side cover before advancing to the upper pinion shaft, I can do that.
#3 It seems that it is basically there by doing #1 or I do not understand.
#4 I am lost. No idea how to identify the center groove.
Pictures attached of upper pinion.
Appreciate the guidance,
Don
#1 is clear
Don
