As I always do, I tried to figure this out on my own. I got no where.
The rear drive shaft assembly connect to the with a coupling with a cotter pin the slides. This allows us to remove the hydraulic pump.
I am not sure if this coupling connects directly to the pinion drive or not.
The curious thing to me is that on the splined shaft that may or may not be the pinion, there is a gear on that splined shaft. The coupling slide towards that gear.
I see nothing that would connect to or operate from that gear. Is it there to throw oil? OR Did my brain implode and I missed something?
Thanks.
Don
Thanks.
Don
