In the manual it says that you can do either the left or the right side.
I have read other posts that explain this is critical for the inner seal. If that is correct, then it seems the end play would be important to both sides.
When I took it apart, I had shims on each side. I had originally planed to just put it back the way I found it as I only changed the inner seal and greased the bearing.
As always, the help is appreciated!
Don
Don
