MF65 Diesel starting instructions decal location?
iknoian
New User
I have the decal for the MF65 Diesel "starting instructions". Where should this go on the Tractor? thanks
Dad's 65 Dieselmatic had that decal, I think it was on the lower dash panel above the fuel stop knob. His also had the Thermostart intake heater, and started well cold using it. DON'T use a Thermostart, or glow plugs and ether together, one or the other, but NEVER both. Diesels also start better cold by cranking five to ten seconds with the fuel stop off, this gets some compression heat built up first before turning the fuel on. Does require a good battery to do this though.
