Hi all,
I am adjusting the draft and position controls. I have 2 shop manuals, Big Dean and a Hydraulics video. Each has a different way to do it. In the end, do they get the job done or is there a difference in result? Below are the DVD and Big Deans instructions.
DVD
Arms lowered (they do not have the hydraulic piston in but assume one should) Position control set to fast, Draft set to center dot, levers adjusted to end of slot with the need for slight pressure. Adjust springs as required. Once done, hold levers to end of slot and adjust cam to touch for response.
BIG Dean
No mention of arms, but I assume in the down position.
For draft adj
Position control in full lift, draft to the dot adjust spring so that draft is 1/16" from edge of slot and can touch with slight pressure.
For position adj
Draft to fully raised position, position lever to fast mark,adjust spring so that draft is 1/16" from edge of slot and can touch with slight pressure.
Response adj
Position lever pressed against slot with cam adjusted to touch lever.
Thank you!
Don
DVD
BIG Dean
For draft adj
For position adj
Response adj
Thank you!
Don
