MF 175 hydraulic set screw?
Camozzi04
What does this set screw do?
It’s rite next to the pro lever and the two hydraulic ports.
It’s an Allen set crew for something.
Aux pump manifold. Should be 2 more holding it as well. Mine came apart with vise grips and I had to get new screws.
(quoted from post at 08:21:40 11/12/18) I think Dieseltech is probably correct, it's been a long time since I've seen one of those so I can't remember exactly either.
Can the screen for the auxiliary hydraulic pump be accessed from here. My multi-power works but my auxiliary hydraulics don’t have much pressure. I can’t get my swather head to lift itself off the ground. Thinking maybe I have a plugged screen?
Here's a picture of my 150 with IPTO. The lift cover also has to come off to get to the filters. There are two, one for the lift pump and one for the Aux/IPTO pump.
(quoted from post at 09:05:51 11/14/18)
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto2662.jpg">
Thanks guys. Really enjoy the 100 series tractors.
