carburetor part
montidale
Does anyone know where to find a venturi for a 444. I have the Massey part number. Called AGCO and the parts are unavailable. It is a Zenith tag no.11979. The massey no. for the carb is 768 476 m91. I can find a float and carb kits ,but no such luck for the venturi. The massey-harris number for the venturi is 1 502-008m1. I can't find a way to cross that no. to a Zenith no.
(quoted from post at 16:13:46 11/11/18) If same part for 44 with 260, I probably have an extra one.
The carb is the same type 62ajx9 and the floats have the same part no. But the venture's have different part no. Maybe the bore of the 444 venturi is bigger to let more air flow for the 277 engine. I'm guessing the 44 venturi will work in the 444 carb though. If I can't find a 277 venturi for my carb I might take you up on your offer. The worst that would happen is it might not have full power at W.O.T
