bowtieboy77
I just finished installing a MF 200 series FEL on to my MF 135. I am using the tractors internal resovoir and hydraulic pump. I realize using the internal pump will limit the whieght capacity and speed of the loader but all it will be doing is cleaning a few small drive ways of snow.
I have installed a divertor valve and a single stick 2 spool loader control valve with float position. The loader valve supply line comes from the divertor. The return line is plumbed into the trans housing return port under the divertor valve. My problem is when the divertor valve lever is opposite then in pic and the square handled lever is in constant pumping position the loader goes up but not down. the bucket will not curl or dump. If I move the 3pt hitch lever down and lower the whieght box then start lifting 3pt hitch as the arms are lifting the loader arms and bucket will work fine until 3pt hitch reaches the top of travel then the loader will no longer function. Wondering if I have my loader supply in the wrong spot or what could be the problem.
