1964 Model 65 AD204 diesel engine
Today I noticed my tractormeter bouncing off zero and failed to indicate anything meaningful. I replaced the tractormeter with one from the e place at the end of January from Reliable Aftermarket Parts and it only has about 23 hours on it. It was $58 plus shipping.
I checked the parts book and there is no drive or any such thing that fits to the end of the meter drive cable; it only pictures a felt washer. The meter drive cable is intact and the drive end is square at maybe 1/8 or a little larger. I didn't measure but it protrudes around 1 1/4", maybe a little more.
When I installed it, I had to screw with it to get it to work by playing with the tightness on the drive cable nuts. I did oil the cable prior to installing.
With the meter just bouncing off zero, has the meter failed already?.
If so where can I get a reliable and lasting tractormeter?
I use this thing bush hogging and rely on the instrumentation to be right or at least pretty close.
I'm going to inspect the square hole in the end of the drive at the camshaft and see what I can up in there. Maybe this square hole is stripped or something?
