I think I need to lower the front end to gain access to the pulley to remove the hub adapter. It looks like the best way to go about it is to lower the axle support assembly. I assume the way we would go ab out changing the belt.
My thought is to support and raise the tractor while removing the axle support bolts mounted to the engine block.
If that is a reasonable idea, where would be the best place to support and raise the tractor?
Thanks for the help!
Don
Don
