After getting the various issues handled with the help of this forum, my 202 has been helping me get a lot of work done.
A new issue surfaced. with the front pump shaft. The pump rotates freely, but has spun at the pulley. My setup does not look like the setups in the Loader Manual. I am hoping I can get some suggestions or guidance.
I have attached 5 pictures
1. Entire shaft
2. End that goes towards the pulley
3. End towards pump
4. Shaft goes through the front
5. Pulley attachment that I assume shaft connects to.
#1 and #2 seem to show a key slot that maybe spun? It is not a threaded end like the 102 loader manual explains.
#3. That chain and sprocket does not connect to anything that I know about, unless it is to power some type of implements. The pump shaft goes inside this.
#4 It seems like the tube goes through the front axle and I can't makes sense of it. I was going to remove the bolts and try to pull it out, but to me it seems the axle rotates on it.
#5 I don't see the kind of space between the axle and pulley that the manual shows and do not see how I would access the plate that attaches to the pulley.
Thank you!!
1. Entire shaft
3. End towards pump
Thank you!!
