gumbellion
New User
Hello
Last night i was servicing my new to me this year 1964 MF FE 35X and i have a problem. From my reading I thought the hydraulic filter was a mesh screen like the multi power one and couple be wasted and reused. When i took the filter out of the rear end i found out about half of the paper element had totally worn away and what is left is basically falling off of the mesh.
It would be a life saver if someone had a NAPA or other parts store (piston ring) part number for the filter in the web link below
It is at a friends place and if i cant get the filter today i will have to drive the tractor home tonight without a filter in it. I would not be using the tractor for anything other than taking it down the road until i could get a filter. But i really want to have it complete. i live in the middle of nowhere so only have napa and piston ring as options
http://www.yesterdaystractors.com/Massey-Ferguson-35_Lift-Pump-Filter_521451M1.html
Thank you very much for your help
there was a lot of gunk on the multi power filter and the old oil was milky. I cant wait to use the tractor with fresh engine and hydraulic oil!
