I haven't been around too many MF's but I am currently working on a MF 50 and upon removing the existing clutch dual clutch (Serial # S6M 537762, 4 cyl. gas engine) I noticed it was covered in oil. Based on the attached photos, where is the oil most likely coming from and how do I go about stopping the leak?
Also, what is the easiest way to tell if the tractor is equipped with a multi-power transmission or not?
What torque do you tighten the flywheel too and what torque do you tighten the pressure plate/clutch too?
Thanks in advance for all of your assistance.
