I have a 1969 Massey 165 multipower with a 204 Perkins. I am experiencing a slow lift on the 3 pt and also when there is a heavy implement (bush hog) it doesn't want to lift it unless it's at 2200rpm and still lifts slow. Someone has unhooked it from the factory levers and hooked it up to a remote lever. It has dual remotes for a loader but a quad remote lever block. There using the other for the 3pt. The 3pt leaks down to after being up for a few minutes. This tractor should have no problem lifting 3-3500lbs. What's wrong !?!
Any help is appreciated thanks !!
