MF 85 power steering conversion kits
1959mf85
New User
I was wondering if there are any power steering conversion kits available for an early 1959 MF 85? My power steering seems to not work at all gonna check pressure and go from there. 3 point works good. pto works good in both positions. Not sure if i can swallow the price of power steering pump if that what it turns out to be.
Check your pressure like you plan, if you need parts we just took in an 85, will have parts, River Dale Farms 920 295 3278
Take your PS pump out and check the seals inside. Some or all may be broke. If you can replace the broken ones, it may improve your steering
some. Also make sure your front axle spindles are greased up and move freely. I had a super 90 that wouldnt steer well. Front spindle was seized
nearly up. Managed to get it greased up and removed some of the rust....and away it went.
Some parts for the PS pump seals, are no longer available, but I have found a substitute that I have had some success with. Get back to me if you
need parts.
Wayne
when checking pressure had line break inside clutch area will get fixed and pull pump and check over.
thanks.
finally got pump torn apart and all seals were broke up to bronze gasket. you said you may have a sub for these possibly?
Hello
I might be able to fix you up. Can you reply to my E-mail....bottom right classic view. Or put your contact E-mail in a reply to me.
Wayne
