Company Logo Shop Now
TractorLinks.com
Alternator not charging
skyler53
11-07-2017 13:48:41
I have a 1965 MF135, GA's Perkins engine. It has an alternator not charging. Alternator checks good. Everything I find shows it came with a generator. It has external voltage regulator. Changing external voltage regulator does not help. I think it has a wiring harnes for generator and someone stuck an alternator on it. I am not sure how to proceed. Do I get a new wiring harness for one with an alternator? Any suggestions would be appreciated on how to proceed. Thanks.
ptfarmer
11-10-2017 14:33:20
 Re: Alternator not charging in reply to skyler53, 11-07-2017 13:48:41
That picture is the one wire GM alternator with the internal regulator.
rvirgil_KS
11-10-2017 07:25:49
Is it an alternator with an external regulator, or old regulator left behind when generator was removed. Picture of alternator and regulator would help.
I agree with Old, if it were mine I would remove alternator and regulator and replace with Delco 3 wire alternator with internal regulator.
ptfarmer
11-08-2017 12:29:49
GM one wire alternator wiring diagram.
third party image
John Deere D
11-07-2017 14:02:59
third party image
third party image
third party image
third party image
Take a Lineman's Pliers,cut and remove the system you have:
Install a ONE wire alternator as per pictures:
If you ask 100 tractor owners of their rendition of "Alternator Conversion", you may receive 100 renditions, ALL with very good merits.
I choose a one wire alternator, as the pulley sizes are such that the engine has to operate, only at 725 RPM to see charging. Here is a ONE wire 12 Volt Alternator Negative ground:
Purchased from YT Tractor Site:
One and only one wire is ran to one side of Amp meter:
Other connector on Amp meter is ran to and connected to Positive supply from BATTERY at Starter:
Three cylinder Perkins Diesel:
I used a Lineman's pliers, removed all the old / original faulty charging circuit wiring and Voltage regulator:
Anything above 725 Engine RPM Alternator operates PERFECTLY:
MF FE-35 X
PICTURES are from "YT's" archives:
Bob...
skyler53
11-07-2017 17:13:16
 Re: Alternator not charging in reply to John Deere D, 11-07-2017 14:02:59
Did you disconnect external voltage regulator? That is my main question? Any other old wiring disconnected? Not sure what to do with that? Thanks
old
11-08-2017 08:28:53
 Re: Alternator not charging in reply to skyler53, 11-07-2017 17:13:16
On a 1 wire you just hook it to the amp gauge and all the other old wires from the charging system can be removed. But many 1 wire set up need a high RPM to self excite. Me I NEVER use them because they can be iffy at best since they are modified Delco 10SI 3 wire alternators. Me I use the Delco 10SI on my machines and any time I convert one to 12 volts and I have done a good many over the years
skyler53
11-08-2017 10:14:37
 Re: Alternator not charging in reply to old, 11-08-2017 08:28:53
I am terrible at electrics. How does it wire up? Thanks
old
11-08-2017 11:11:28
 Re: Alternator not charging in reply to skyler53, 11-08-2017 10:14:37
The Delco 10SI is like what would be on a 1980 Chevy pickup. No AC no power windows etc. Then to wire it up there is a 2 wire plug you would need to buy. It is marked 1 and 2. The #2 wire goes to the charge stud and the wire from the charge stud goes to the amp gauge. The #1 wire goes to the ignition switch the side that is hot when turned on. On many I just run the wire to the ignition side of the coil. But in many cases one has to have a light bulb or diode or a ballast resister in line of the #1 wire or you cannot shut the engine off. But all in all easy to wire up
John Deere D
11-07-2017 18:26:14
*****PLEASE NOTE:
I swapped out a Generator on my 1963 MF FE 35 X Diesel, that has NO FUEL gauge or any other pressure sensor type PRESSURE to ELECTRICAL TRANSDUCERS.
I used a Lineman's Pliers, cut off each wire / conductor from its source that was attached to the VOLTAGE REGULATOR.
Then I placed the Voltage regulator and all connecting wires to and from the Voltage regulator in the Dumpster:
I would believe the Electrical wiring on a MF 135 is different than a MF FE 35 X Diesel?
The PICTURE of the MF 135 from the "YT" Archives, I believe was posted by "ptfarmer"
Bob....
old
11-07-2017 14:00:10
If it where me I would stick a Delco 10SI on it. An alternator like the one on a Chevy pickup. 1980 no power any thing no AC. Easy 3 wire hook up and built in VR so easy to wire up
Copyright © 1997-2020 Yesterday's Tractor Co.
