I have a MF135 That I took the side housing off to clean the hydraulic filter. When I put the side housing back, I must have not gotten the lever in the notch on the gear. Did not use the tractor PTO since I cleaned the filter. That was till yesterday. Tried putting the lever to the engine side the PTO did not work. Moved it to the ground speed side the PTO worked with the tractor moving. Moved the lever back to neutral and the PTO kept turning. So I drained the oil, removed the side housing and seen the gear was engaged in the ground speed gear. So I did not get the lever in the notch when I put it back together when I cleaned the filter.
Let me tell you before cleaning the filter, when engaging the PTO to the engine side it never grind going in to gear. Now I put it back together it grinds when to try to engage the engine side of the PTO. I read about the PTO clutch plate need adjusting can cause the grinding. But as I stated before it never grinded before. Tried making sure the spline shaft on the engine side lined up with the spline of the PTO side with the gear engaged in the ground gear. So the spline shafts lined up and the gear slide and engaged with no binding. Installed the side housing back moved the lever thru from ground speed to neutral to engine with the engine off. No binding. Start the tractor and try to engage the engine side of the PTO. I get grinding and sometimes able to get the lever engaged to the engine. All with the clutch depressed. Remove the side housing again and the splines are off just like 1/8 of a tooth. Tried doing this about 4 times and still having the same problem. I am out of ideas.
Thank you,
Adam
Thank you,
Adam
