Geo-TH,In
Helping a friend/neighbor with his 1963 MF 35. As you can see from the first pic, someone damaged the top link. Pic 2, someone added a remote valve. Pic 3, position he keeps the draft lever and quadrant lever kept in all the time.
Friend was told by the guy he bought the tractor from to position the levers as in pic 3 and to make the 3 pt go up and down use the lever with red knob closest in pic 2. That does make the 3 pt go up and down. Complaint, he has no control over how fast or slow it goes up and down and no control over where the 3 pt will stop.
I have a ford Jubilee. It only has a quadrant lever. Draft is a lever on side of sump. I have no remote valve.
If there isn't damage to the linkage under the lift cover, I'm thinking he should be using the quadrant lever to control up and down movement of the 3 pt, at least that's how it works on my Jubilee. If I'm right, then where should the draft lever be? Where should the lever with the red knob be?
Also what kind of oil should he use in tranny and hyd/rear end? How much?
At the moment, the tractor is being taken apart and all fluids have been drained. So, there is no way to test it. I'm hoping he doesn't have to remove the lift cover.
Thanks in advance
George
Thanks in advance
George
