Massey 150 gas
1100D
New User
My dad has a 150 with a loader on it, the tractor steers hard. The front spindles take grease and seem tight. does this tractor have power steering? What could be causing this problem?
Thanks for all your input.
Are you asking us if it has power steering? Does it have a power steering pump at the left front corner of the engine and a slave cylinder between the grill and radiator? If it does have power steering, the problem could be with the adjustment of the valve and/or worn linkage to the valve.
If it has power steering, you will see a pump and tank bolted just in front of the distributor. Lines will run from pump to power assist in front of the radiator. Check steering box for lube (90 wt) there are also lube fittings on the spindles, kingpins, assist linkage, and steering pivot.
