1961 MF 35 Need Help Wiring Voltage Regulator
1hgfire
New User
HELP NEEDED I’m wiring a voltage regulator on a 1961 Massey Ferguson 35 with 3 cylinder Perkins. Can anyone send a wiring diagram. Like the original, the replacement regulator I’m installing has a “F” terminal, a “BAT” terminal, a “L” terminal, and a terminal on the bottom unlabeled, but same terminal on the one removed was stamped 4M, 12V, P/N. The “F” and bottom terminals (4M, 12V, P/N), were wired to the Dynamo. The “BAT” terminal I believe was headed toward the instrument cluster, and the “L” terminal was not connected at all. Having problem finding wiring diagram. Can anyone tell me how to wire this voltage regulator.
Desperate,
Phil
I hope these show up, this my first attempt to post a picture. I also hope these are what you are looking for.
C. T.
By the way, the titles on these pictures are "Diesel Lights", "Diesel Wiring", and "Manifold Preheater", not that you or anybody else needs the titles.
C. T.
Looks like this diagram will work all though i have a Perkins diesel the terminal connections look the same.
Thanks a Bunch willowbk and God Bless
C.T. these diagrams are perfect even better than I hoped for. I also welcomed your sending the titles as well. Its great to have a friend in Oklahoma! By the way what was your source for these diagrams?
1hgfire
Phil,
I'm embarrassed that I didn't give credit to one of our really nice and helpful contributors, the late Big Dean. I have his CD and I copied the diagram from it. Thanks for reminding me.
C. T.
