8120 massey
Anonymous-0
I have a 8120 massey mfd and I am trying to remove the engine oil pan. I believe I have all the bolts removed as well as the front axle. The back of the pan is loose, bit the front is quite tight. I have also removed the 4 large bolts that go through the front casting into the pan. I am sure there is a trick to remove this pan, but I do not have a service manual. Thanks
SOME PERKINS, MASSEY ENG PANS WERE BOLTED AND CROSS BOLTED, LOOK FOR HIDDEN BOLTS , COMMONLY IN VERRY DEEP RECESSES, OR HIDDEN UNDER GREASE , DIRT. DO NOT PRY !!! THIS IS ESPECIALLY TRUE IF IT USES THE FRONT OF THE ENG TO MOUNT THE FRONT AXEL. ASK ME HOW I KNOW!
