Hello,
I have an MF-50 that's not getting spark, and I'm stumped as to why. The coil puts out nothing to the distributor cap, and a new coil has not solved the problem. I've tried a few troubleshooting methods and found out that there are 12v going in to the coil when the ignition switch is on, but test light indicates that the current is totally lost while cranking. I've tried jumping the ignition switch and the starter button in case they were bad, but current is still lost.
I don't know much about ignition systems... basically I've learned everything I know in the last couple days looking online for troubleshootng. But it seems to me as though the points close in order to complete the ground on the coil to make the coil put out current to the distributor cap. If that's true, the points not making contact would mean the coil is not grounded, preventing it from putting out any current. Unless it's a condenser problem, or both. Any ideas?
Thanks for your time!
