354 perkins injectors/ injection pump
Anonymous-0
I have an oliver 1850 diesel with the 354 perkins non-turbo. I pull competively in the non-turbo classes locally but I'm looking for more power without a turbo. I have already maxed the pump and believe that the injectors are bad. I know MF used the 354 perkins in many of their tractors and combines. Does anyone know or have an opinion of what combine/tractor I need to get the injectors/pump from? thanks
510, 750, 760 combines all had 6-354's as an option (turbo and NA)
1100, 1130, 1135 tractors offered them as well. (Turbo and NA as well)
Oliver/White used 6-354's in some combines.. Not sure what all ones..
I'm not sure you could use a combine IP on a tractor for sure though.. I know on the V8 perkins from combines some of the throttle setups work opposite of the ones in tractors..
Brad
