Greg in KY
I think this was discussed a little while back but I cannot find it.
135 diesel- 1st time I had used it, unknown history- seems to be in good condition.
I had been using it with a sickle bar mower for 2-3 hours. Everything working as it should. Then the motor would rev up about 250 rpms(from about 1500 to 1750) for maybe 2 second up to about 10 seconds then go back to the 1500 rpms. It did this maybe 10 times in about 15 min.
The throttle lever never moved. I do not believe the throttle linkage moved on the pump. I may have been only while going up hill but not for sure. I could not make it do it again.
Then it ran normally for about an hour more until I quit using it.
What going on?
Thanks, Greg
What going on?
Thanks, Greg
