I"ve been trying to figure out where the fuel in my Engine oil on my 1130 is coming from, I"ve replaced the lift pump, checked the Injector pump seals and they appear to be fine, I think I"ve narrowed it down to a possible Injector Problem? The Owners Manual states if there is Engine Knocking that it"s a faulty Injector, and occassioinally under load it will scare the heck out of me and a puff of smoke, then it clears, Oil Pressure never drops, and I"ve replaced the turbo. Lately it seems to run fine, but i do notice a puff of smoke which seems to be rather consistant with one of the cylinders. Could this be a Injector, or worse, rings? How does one tell which Injector to check, and how does one know if it"s bad? Also should they all be replaced or can one replace only one or two depending on how they are?
