MF 204 convertor
1031D
I pulled the engine out of the neighbors MF 204 Work Bull with a Z134 engine. When I spun it around to get it out of the way I noticed the 2 tabs sticking out of the back of the torque convertor are half worn off. Is this something I should worry about and is it a part that can still be bought?
I would definitely replace this part, as these "tangs" drive the charge pump, in the front of the transmission. I would also replace the seal in the front of the pump, before re-fitting the engine.
Evan.
