I was going to wait until I could do more testing on this but I'm home sick in bed, the ground is muddy and I probably won't get back on the tractor for a bit, so:
I read in the archives something about adding springs to fix a locking brake problem. Didn't really understand where these springs were being added but it got me wondering.
When my brakes lock they usually stay that way, though the brake pedal and linkage all the way to the threaded adjuster rods return to the normal unlocked position, with the adjuster rods remaining out in the locked position. Long story short, I rigged up some external springs that push against the adjuster nuts. I've only been able to test it once, and it seemed to work on one side, the other still locking. I was planning on increasing the spring pressure, but with only a rudementary understanding of how everything is connected inside, i'm wondering if I'm just wasting my time with this? I only use this tractor to move the backhoe from place to place on loose soil so the locking brakes are not a big issue at this point, but it would be nicer if they didn't.
TIA,
Paul
TIA,
Paul
