I have an MF135. I am having a problem with the front end loader hydraulics. I started my tractor after two months of non-use. The rear hydraulics worked, but front end loader did not even twitch. I drained the hydraulic fluid, cleaned the metal filter, and put in new fluid. Front hydraulics are still not working; PTO and rear work. I have a lever under the right side of the seat to shift from front to rear hydraulics. With the lever set for front hydraulics, I disconnected the hose that goes to the front hydraulics, but no fluid came out.
What am I missing? Doesn"t the same pump service both the front and rear hydraulics? Is there a second filter? How can I determine what is wrong?
Thanks in advance for any help.
Tony-37
Tony-37
