Lower link wrist action ball ends
timberwolves
New User
Does anyone know how to rebuild the lower link wrist action ball ends on a MF-65 ? The spring is missing and the link does not lock in. I purchased a lift arm lock pin kit and it comes with 2 washers, spring , bushing & 2 what looks like press in pins ? Thankyou John
John,
After you have all the old parts removed, install the new spring
first then the bushing pushes against the spring. The bushing is
held in place by placing a washer on each side of the lift arm and
beating the press fit pins through the washers and into the part
you are calling a bushing. Make any sense?
